TomU
Jun 17, 2016 1:23 PM UTC
Removing Old Servers
Does anyone know of a way to remove or hide old systems (GUIDs) from the dashboard?  I've spun up a bunch of different test systems and also created some duplicates (with different GUIDs) using the GUID generator tool after rehosting.  I would like to know how to remove or hide the systems that are no longer needed.
MarcoTosin
Jun 17, 2016 1:35 PM UTC
Hi Tom,
I have same question.
At the moment I'm waiting to see if after 90 days old servers will disappear automatically.
Another strange thing is about transmitted data gadget where it counts two data for every day.
Marco
TomU
TomU23-Emerald IVAuthor
Jun 17, 2016 1:40 PM UTC
I think this is because two separate files are transmitted to PTC each day.  One is a zip file and the other is a properties file describing the zip file and your SCN.
MarcoTosin
Jun 17, 2016 1:58 PM UTC
I'm with you about the two zip files.
But I'm wondering why it counts two.
I think that if PTC it expect two files to sign data transmitted successfully should be count 1 and if there aren't two files should be 1 fail transmitted data.
Marco
MarcoTosin
Oct 20, 2016 12:27 PM UTC
Hi Tom,
below some fresh news arrived today from TS about removing old servers.
Hi Marco,
As per R&D (11th of October) the implementation is done. They are just waiting for QA’s sign-off.
I will ask for a fresh update and keep you posted.
Best regards
Michael
Marco
TomU
Oct 20, 2016 12:40 PM UTC
Thanks Marco Tosin‌.  I too heard something similar.  Sound like tech support will now be able to manually remove unwanted GUIDs.  No idea if they will extend this out to the end users or not.
MarcoTosin
Oct 21, 2016 12:27 PM UTC
Another update from TS.
Hi Marco,
R&D is currently looking into the "update of GUIDs" issue.
A first attempt to fix it had to be rolled back.
Other customers are also requesting the same feature.
We will get some update soon hopefully.
Marco
