Jul 27, 2015 9:08 AM UTC
Rename a WT part using Import from Spreadhseet
Dear Experts,
I am trying to rename a WT part name using Import from spreadsheet functionality even though I receive a message stating that validation is succeeded, I dont see the change in the name of the Part
Can some one suggest a way to fix this
Currently I am using WC 10.1, M040
Athmanand
2-Explorer
Jul 27, 2015 1:44 PM UTC
I don't think import from spreadsheet or loadfromfile could help in renaming wtparts. You could modify structure by adding or renaming components. You can write a custom utility to do that. By the way what does your methodserver log file say?
Binesh
Barry Wehmiller
2-Explorer
Binesh
Barry Wehmiller
Anand1-VisitorAuthor
Jul 27, 2015 2:25 PM UTC
Hello Binesh,
Thanks for the clarification
Completely forgot about method server , Let me check it
Athmanand
Jul 27, 2015 4:13 PM UTC
Athmanand,
if you want to write custom utility then below are some sample API which u need to use
public static void renameWTPart(String[] array) {
// Read csv file to get the original number, new number and name,
  String orgNumber = array[1];
  String oldName = array[2];
  String newNumber = array[3];
  String newName = array[4];
  WTPartMaster partMaster = null;
  WTPartMaster dupMaster = null;
  String message;
  try {
  // Search for existing part
  partMaster = (WTPartMaster) getWTPartMaster(orgNumber);
  if (partMaster == null) {
  message = "ERROR: Can not find WTPart: " + orgNumber;
  addToLogs(message, logFile);
  // If we always return true then the load will continue
  return;
  //search for with new WTPart number incase if part already exist
  dupMaster = (WTPartMaster) getWTPartMaster(newNumber);
  if (dupMaster != null) {
  message = "ERROR: WTPart already exists in database: " + newNumber;
  return;
  try {
  // change WTPart identiry i.e. rename
  WTPartMasterIdentity partIdentity = (WTPartMasterIdentity) partMaster.getIdentificationObject();
  orgNumber = partIdentity.getNumber();
  partIdentity.setNumber(newNumber);
  partIdentity.setName(newName);
  IdentityHelper.service.changeIdentity(partMaster, partIdentity);
  PersistenceHelper.manager.refresh(partMaster);
  message = "SUCCESS: Renamed successfully: " + orgNumber + " to " + newNumber;
  }// try
  catch (WTException ex) {
  message = "FAIL: Rename error: " + orgNumber + " to " + newNumber + ": " + ex;
  return;
  }// try
  catch (Exception ex) {
  }// catch
  public static WTPartMaster getWTPartMaster(String orgNumber) {
  WTPartMaster wtPartMaster = null;
  QuerySpec qs = null;
  try {
  qs = new QuerySpec(WTPartMaster.class);
  SearchCondition sc1 = new SearchCondition(WTPartMaster.class, "number", "=", orgNumber);
  qs.appendWhere(sc1);
  QueryResult qr = PersistenceHelper.manager.find(qs);
  if (qr.size() > 0) {
  wtPartMaster = (WTPartMaster) qr.nextElement()
  } catch (WTException ex) {
  ex.printStackTrace();
  return wtPartMaster;
Hope it helps !!!
Shreyas
Jul 27, 2015 3:02 PM UTC
I have a utility that can mass rename WTParts in Windchill.  It can do either name, number, or both.  It is run from a WC shell and the input is a simple CSV file.
If you're looking to do a large mass rename, let me know if you're interested and we may be able to work something out.
11-Garnet
Sep 9, 2021 10:22 AM UTC
Hi
Is there any OOTB rename utility for mass rename for WTPart?
If not pls share your utility
Afroz
avillanueva
23-Emerald II
Sep 9, 2021 12:39 PM UTC
I believe the import from spreadsheet will rename objects but also iterates them.
Jul 29, 2015 2:05 AM UTC
Dear Shreyas,
Thanks for sharing the details,
@ Bob is your utility similar to the one shared by Shreyas
Athmanand
Jul 29, 2015 12:18 PM UTC
It's a bit simpler in terms of the setup, but yes the concept is the same.
Jul 29, 2015 2:08 AM UTC
@ Binesh,
You are right,
Column Header
Required
Editable on reimport
Description
Action
Yes
Actions include Add or Delete.
Type
Yes
No, class type cannot be changed for existing parts
Class type, logical identifier, or an external type ID. For example:
  • for OEM parts, use wt.part.WTPart
  • for manufacturer parts, use com.ptc.windchill.suma.part.ManufacturerPart
  • for vendor parts, use com.ptc.windchill.suma.part.VendorPart
Note
The class types can be defined in the logical identifiers file with an alias. For example, wt.part.WTPART=part. Part, Manufacturer Part and Vendor part will be included in the logical id file.
Name
Yes
No, part name cannot be changed for existing parts
Part name.
2-Explorer
Jul 29, 2015 3:29 AM UTC
Thanks Anand for confirmation.
