May 24, 2022 3:43 PM UTC
Rename from Workspace is greyed out
One of the constructors has a problem with rename part. He has the same privileges and is in the same groups/roles but rename option is greyed out. Where did we suppose to look to fix it? It is urgent.
MattPatAnswer
May 25, 2022 1:21 PM UTC
We found the solution and it is very odd too.
Changing the windows browser type to ie_browser in creo helps. I don't know why it was not working on chromium...
May 24, 2022 6:28 PM UTC
Is it checked in?  Then you cannot rename through the workspace.  You have to rename from a search.
TomU
May 24, 2022 7:52 PM UTC
@STEVEG,
It wouldn't have the new icon (asterisk) if it was checked in.
May 24, 2022 9:59 PM UTC
Ah.  Missed that.
It probably won't be profile but check it anyway.
Is the other user trying to rename a file that is not checked in?
May 25, 2022 1:18 PM UTC
This is very odd.
Question:
You said "One of the constructors has a problem with rename part."  Did you really mean "constructors" or did you mean "contributor" like in the image you show.
If you did mean contributor then I assume both users are in that role?
MattPat14-AlexandriteAuthorAnswer
May 25, 2022 1:23 PM UTC
Wow!  I'm glad you found the problem.
