Rename Number - OIR appears to be correct
  • July 6, 2011
  • 2 replies
  • 739 views
I just opened up a call with the hot-line, but I thought I'd try here also.
I need to rename some files, however I'm not able to rename the number. I checked the oir for this product and it appears to be setup to allow that. I'm stumped. I HAVE to rename the number on these files.
The OIR for epmdoc's has this in it:
<attrvalue id="number" ignore="true">
<arg>/Default</arg>
</attrvalue>
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
22-Sapphire I
July 6, 2011
Need the permission: Modify Identity (for every existing Iteration's current state).
I think you have 2 identical discussions regarding disabling autonumbering:
Just add this at the bottom of the OIR for EPMDocument:
<attrconstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</attrconstraint>
</attributevalues>
In Reply to David Haigh:
/Default
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
