Jan 14, 2016 9:03 AM UTC
Renaming multiple objects with progressive numbers, all at once
I would like to rename a set of objects in Windchill with progressive numbers (Cxxxx_1, Cxxxx_2, etc. etc.), all at once with a single command (the number of the objects is very high, so would be infinite to do it manually).
I know that the rename command (label icon) in the rename window can rename multiple objects for example with the same string, but I don't know how to set the progressive number (which would go according to the order objects are listed in the list, tmuch importance on this anyway).
Anyone knows if it is possible?
thanks
Bye
Tommaso
Jan 14, 2016 3:08 PM UTC
My company developed a java utility that will rename objects.  The input to the utility is just a CSV file of two columns (currentNumber,newNumber).  It currently works on EPMDocuments or WTParts, but I am sure we could extend it to work on WTDocuments if necessary (or other object types).  We can also update any or all of the number and name (for WTParts), or the number, name, and filename (for EPMDocuments).  It runs via command line on the Windchill application server.
We have successfully used this utility to perform rename on an order of magnitude of several thousands to low tens of thousands of objects.  If you are interested please send me a direct e-mail.
tleati12-AmethystAuthor
Jan 22, 2016 12:56 PM UTC
Hello Bob,
thanks for your reply. Your software sounds interesting and would be useful too, but unfortunately indeed I am not allowed to install external applications which may interfere with the data (sure anyway that your utility is safe and tested).
It just seemed strange that there wasn't an embedded function like the one when you "save as" an assembly which puts a suffix like the default "_" at the end of the name. But I see there is no possibility like this. (fortunately in my case items number is not thousands as yours, so I can make do with manual work this time).
thanks
bye bye
Tommaso
Jan 14, 2016 4:05 PM UTC
Hello
it is possible to do many various "mass" activities but generally it requires some custom application.
The one my consultant did a few years ago work in a similar way than what Bob described.
A csv file need to be prepared, the structure of the file could be
CurrentNumber,New Number
but it is not limited to this. I once had a project to align systems and over 70 000 Wtpart, related models and drawings needed to have parameters changed, we had Name, Number, Filename . We also needed to do it for some specific version only.
So the first two columns of the CSV file were to identify the object
Current Number, Version
the rest was the new data so the CSV looked like this
Current Number, Version, New Number, New Name, New Filename
It requires some preparation to create the CSV file but also some testing to ensure data are not messed up.
It took a few months to prepare the data, test, validate the data but on the production server, we modified  ~15 000 objects per hour.
I am not aware of PTC utilities to do mass changes on this kind, so if you cannot program yourself or have someone within your company, you will need the help of an internal. For us, it took a day for the consultant to write the application, we tested it, there was some issues, so it got improved. Overall I must have paid about 2 to 3 days of consultancy work.
Good luck and let us know how you get on. Thanks
Best regards
Jan 22, 2016 1:06 PM UTC
Hello Chris,
thanks for your reply. Do you know whether PTC is currently foreseing to develop an embedded utility like yours or Bob's? The fact is that since I cannot install software which may interfere with the data (with catastrophic consequences), possible solutions would be to have a PTC utility (thus certified and insured as far as our contract is concerned), or to look for a consultancy service like you did (as much insured in case of possible problems).
I was just wondering whether there was a special function somehow and somewhere.
thanks
bye bye
Tommaso
Jan 26, 2016 3:39 PM UTC
Hi
I can speak for Windchill 11 but for 10.x if there was one I would have used it.
Surely whoever decide such rules in your company as to balance his policy vs work involved to cleanse the data.
Also, you never do such mass changes before many rehearsals on test server. So the changes something go wrong on production is close to 0.
Good luck.
