3-Newcomer
Mar 26, 2024 8:32 AM UTC
Replace part in BOM
If I would change a WT Part in BOM, do I need to update all the Drawings inwhich is inside the item?
Do I need to update all the BOM in the Drawing or Winchill recover it? version CREO9 and Windchill
Best regards
Dino
Mar 26, 2024 1:37 PM UTC
The drawing BOM is driven from a repeat region BOM table on the drawing and is not being driven from the Wtpart and the BOM structure. You will need to open the drawing in Creo and update the assembly structure, so it matches your WTpart change, then regenerate the BOm table.
