Sep 5, 2023 11:08 AM UTC
Replicate SQL Database & Windchill Directory Server from Production to Test Environment
I need to replicate SQL Database & Windchill Directory Server from Production to Test Environment
Sep 5, 2023 2:07 PM UTC
Read the Rehost guide for your version of Windchill. It is not for the faint of heart!
jbailey
18-Opal
Sep 5, 2023 11:16 PM UTC
The most convoluted document PTC has created to date :-P.  It doesn't help that the scenarios they include don't even discuss deployments that are using the new model (no supplied java, no WC DS etc)
HelesicPetr
Sep 6, 2023 5:52 AM UTC
Hi @jbailey,
The documents are good for general knowledge.
If you've never done a clone of the system you should start with general knowledge documentation to understand what have to be done ,
So I would start with the rehost guide
Windchill rehosting is very complex operation and you could do many many mistakes.
PS> not you but anyone 😄
PetrH
avillanueva
23-Emerald II
Sep 5, 2023 2:13 PM UTC
Not sure of what version but this should cover all bases:
https://www.ptc.com/en/support/article/CS162685?source=search
