Report by Transition or Mail robot
I need a query builder report but I don't know how to get it.
I want to get the list of Change Forms where "Skip" Transitions are used or "Cancel" mail robot is used in the activity.
Can you help me?
HelesicPetr
Hi @OnurNalbantgl
The point is that you need to use outer join or something like that because , the information in the WFVotingEventAudit does not exists for terminated tasks
So you need to get results where rows does not exists in the WFVotingEventAudit table.
PetrH
HelesicPetr
Hi @OnurNalbantgl
A table select * from wcuser.WfVotingEventAudit contains information about existing Activity that have been completed.
column eventList contains the voting information if the Skip has been used.
column processName and ProcessTemplateName can be useful for additional search.
also a link to WorkItem is idA3B6
Hope this can help
PetrH
Hi @HelesicPetr
Unfortunately, I tried all the options in WfVotingEventAudit, but I still could not report the information in "link properties".
What I needed was to be able to see through which "transition" the activity was progressing
But I guess it doesn't work.
HelesicPetr
Hi
You need to  sesrch it
informstion is somewhere because workflow explorer can show if the task has been terminated or skiped
keep searching
ps: i can help next year 😎
PetrH
