22-Sapphire I
Aug 1, 2013 7:11 PM UTC
report group membership
ref: CS22167
From Org, Groups UI, one can see all members of each Group. There is no way to output this to a file. Cannot get info using any Windchill report.
Has anyone solved this problem (found a way to export Group membership to Excel)? We're required to periodically audit membership and this would be very helpful.
Aug 1, 2013 7:26 PM UTC
It is NEARLY impossible.
We managed it by:
- Creating a custom Oracle function that,
- populates a materialized view which is then,
- pulled into Excel via ODBC
That is the roadmap. Sorry, I can't provide any source code.
joe bell
Aug 1, 2013 7:30 PM UTC
(edit)
We managed it by:
- queries your LDAP,
joe bell
20-Turquoise
Aug 2, 2013 2:02 PM UTC
On 08/01/13 14:11, Mike Lockwood wrote:
> ref: CS22167
One possible solution is using the WindchillDS/server/bin/control-panel. You can copy an paste from
there into something or export as an ldif file.
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Aug 2, 2013 4:25 PM UTC
I've been told that you can create a Custom Report via InfoEngine that will pull the information from Windchill and the Group Membership information from WindchillDS.
[cid:image001.gif@01CE8F62.371BAA50]
Steve Vinyard
Senior Solution Architect
Aug 5, 2013 11:31 AM UTC
Hi Guys ,
I believe it is possible , I would suggest to create a Document Link in Library and pull a report hitting the WTGroups (DB) and pcking up users from the Groups with WC APIs.
It should work.
regads.
Sriram Rammohan
Aug 5, 2013 3:51 PM UTC
1.Authenticate WindchillDS directly from java API and get the group
information.
2.get WTGroup from String format then trace its child members.
3.this feature might be OOTB feature,please check in preference also.
22-Sapphire I
Aug 5, 2013 3:57 PM UTC
We paid a consultant for a Windchill shell-based tool – works perfectly.
Aug 5, 2013 9:07 PM UTC
Put together a Windchill command line tool for generating the groups and
members information.
The tool uses Windchill APIs for retrieving the groups and members. Please
shoot me a line for more information.
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
May 6, 2019 12:38 PM UTC
Hi Swamy.
Could you tell more about this command line?
