3-Newcomer
Nov 5, 2025 10:01 AM UTC
Report to get Empty workspace in windchill
Dear Team,
We are seeking a report that identifies all empty workspaces in Windchill.
Has anyone previously worked on a similar requirement or developed a report for this purpose?
MarcoTosin
Nov 5, 2025 10:19 AM UTC
Take a look at this discussion and see if it can help you.
https://community.ptc.com/t5/Windchill/Workspaces-with-their-sizes/m-p/1036480
Marco
18-Opal
Nov 6, 2025 6:05 PM UTC
@NK_13235355
Once you know which workspaces are empty what do you intend to do?
I just created a Query Report that returns the name of workspaces that have no objects.
I also wrote a sql query to do the same thing.
You need only two tables to do this so it's pretty simple.
If you intend to delete these empty workspaces, I'd recommend writing a custom Java class that you can run from a Windchill shell that gets the empty workspaces and then deletes them.
3-Newcomer
Nov 10, 2025 6:13 AM UTC
@d_graham Currently we are checking the count of empty workspaces available in system. As you mentioned, Based on count we will decide to create utility to delete those empty workspaces.
Could you please guide me or share QML to get the empty workspace report
