Reporting using Cognos
We have started learning some reporting techniques using Cognos. I have few concerns about how it works with Windchill. I am not sure if we are missing something here?
* Adding new columns to existing report in the query builder report does get passed into Cognos report until you restart Cognos service and Windchill. This seems like so much burden on the admin side where you have restart Windchill production now and then to update the Cognos reports to show the data in newly added column.
* Creating hyperlinks to the Windchill objects: We need to hard code the URL of the server and URLEncode to get object id. I was so frustrated that the report expression in the hyperlink column was getting corrupted if I start typing the expression. I had to undo all the changes and make a new Cognos report, not reliable.
* Once the Cognos report is built on the development machine: we always have to tweak the URL to get the correct hyperlink on production after deploying the report in production. Or modify the xml itself.
* Vendor specific functions(ex Oracle functions) does not work at all.
Please share your experience. Is anybody using Cognos in production yet with Windchill?
Thanks for your help.
Preeti
Preeti
