Reset Current View
9.1 M040 WF5m030
I've been searching thru all the Help content trying to find somethign that controls the resetting of the table display.
I have a custom view defined to display and sort as desired. However, once in a while a user will pick a column header to sort by to change the sort order. It seems the only way to get the defaults back for the defined custom are to switch to a different view, then switch back.
Are there any preferences I cannot seem to find that chang the way this acts?
I'm considering a second custom view, that shows nothing just to speed up the process of reloading the desired view.
