Feb 4, 2025 2:09 PM UTC
REST API: How to find Referenced by Part, starting with a known document?
Version: Windchill 12.0
Use Case: Using REST, I can start with a known ID for a WTPart, and find the documents that are linked to the part using /ProdMgmt/Parts/References. When starting with a known document ID, I cannot find an endpoint that will allow me to get the Referenced by Parts, even though using the UI, I can see them.
Description:
Is there an Endpoint for getting to the Referenced by Parts data, using standard end points, or am I stuck looking at a custom endpoint, or modifying an existing one?
Catalina
Community Manager
Feb 11, 2025 8:31 AM UTC
Hi @sblaske
Thank you for your question.
Catalina | PTC Community Manager
