Jan 24, 2024 11:07 AM UTC
restart windchill with error
FATAL [main] wt.method.server - MethodServerMain abort
wt.util.WTRemoteException: Unable to register server; nested exception is:
 java.lang.SecurityException: access denied
Rocket_Max
Jan 25, 2024 12:55 AM UTC
Did you clone the environment from source before upgrading?
It seems that you have not modified the following information:
  • java.rmi.server.hostname property in the wt.properties file
  • Hosts file:
    • etc/hosts for Unix platforms
    • C:\Windows\System32\drivers\etc\hosts for Windows platform
Please confirm above!
Refer to:
Article - CS389130 - Server cannot be stopped with an error: wt.util.WTRemoteException: Unable to register server; nested exception is: java.lang.SecurityException: access denied in Windchill PDMLink (ptc.com)
Solved: Re: java.lang.SecurityException: Access denied - PTC Community
Article - CS150162 - ServerManager throws error Unable to register slave cache in Windchill (ptc.com)
jbailey
18-Opal
Jan 24, 2024 11:24 AM UTC
Can you share more of the stack trace?
avillanueva
23-Emerald II
Jan 24, 2024 11:50 AM UTC
What OS are you on? Spit balling as we need more information. Could this be file access related? Installing as root but running as another user? Could this be services like SELinux or fapolicyd? Could this be Java certs issue (less likely)?
jbailey
18-Opal
Jan 24, 2024 7:44 PM UTC
I have even seen similar on an out of memory error, or maybe an expired SSL cert
Rocket_Max
  • Hosts file:
Refer to:
