Restrict list of participants for a workflow task to users under a role?
  • January 19, 2012
  • 6 replies
  • 3543 views
Does any one know how to limit the participant choices for a workflow task to only those members listed under a role in a product or library container? I know this can be done as I see it done in the "Change Request workflow" where the participants for the task is limited to only those under the "Change Admin I" of the context. I try to do this in my workflow, copying I think every attribute of the "Change Request workflow" into mine to make it just like the CR workflow and it just does not work. It allows me to select anyone in the context - not just those under the role.
I am on Windchill 9.1, m050
Any help would be appreciated as this is very frustrating.
Best answer by JamesBaile
Do you have a defined list of participants? or does it change by what is being promoted?
9.1 M060 and we use a custom promotion request process here
rdanner1-VisitorAuthor
James, thanks for the reply.
It is a defined list of participants under the "Promotion Approvers" role in the context. I have a preceeding workflow task to "select participants", I want that selection list restricted to just those under the "Promotion Approvers" role.
You second question: "or does it change by what is being promoted?" is very interesting. Is that possbile?
22-Sapphire I
January 20, 2012
In each workflow Activity in the template, you choose where to obtain the people / groups to fill the Role. If you want to use the context team, need to
a) set up a team template that includes the Role but no people
b) configure the workflow Activity to point to it
c) populate that Role in the context
Mike, thanks for your reply, and I looked at your other postings and it seems you have a good understanding of workflow. Sorry to say I do not.
on item B) configure the workflow activity to point to it - How? List it as the role resource or point to it to resolve roles at runtime for the activity?
22-Sapphire I
May 17, 2012
In the Workflow template, select the Activity, then select the Participants tab. You can select Roles, Groups, Users, etc. You can map these in various ways (e.g. the Approve Role is the Engineering Group). But also look at the last 2 tabs - these determine where people can be obtained for each Role.
Need to play with these a bit. The main objective is to have a workflow at Site or Org level mapped to a Role, then have the system find the users for that Role in the current Product (or Lib). So for example, the same Approver Role could resolve to Joe in Product 1, but to Sam in Product 2. This is very powerful and far-reaching and worth really getting to a point of full understanding.
If you like, I can show you on a webex.
