2-Explorer
Nov 16, 2018 10:47 PM UTC
Restrict Printing and download
Greetings,
I would like to create an Org level Group within a context that has restricted printing and downloading permissions. I see the ACL's to restrict downloading, but don't seem to see how one would prevent them from printing a document.
Our documents are PDFs, we are also restricting this Group from seeing any source documents.
Any ideas about restricting printing?  I'm assuming it has to be in Creo View.
- James -
Windchill 11.0 M030 CPS08
WGM 11.0 M030
Inventor Pro 2017
Windows 10
TomU
TomUAnswer
Nov 19, 2018 10:41 PM UTC
Bummer.  I just did some searching and found this, which says the same thing:
https://www.ptc.com/en/support/article?n=CS177324
TomU
Nov 17, 2018 11:06 PM UTC
It is possible to restrict printing from Creo View.  Take a look at this article:
https://www.ptc.com/en/support/article?n=CS32479
I do not know if this still works when a PDF is opened from Adobe Reader inside Creo View.
JHall2-ExplorerAuthor
2-Explorer
Nov 19, 2018 2:21 PM UTC
Thanks, @TomU
I'll check into that.  Also, it seems that if there was a PDF as Primary Content in a WTDocument, if you could download it, then, as you say, it would open in Adobe Reader, and you have the ability to print and save as from there.  I might have to restrict downloading of PDF's completely.
James
TomU
Nov 19, 2018 2:26 PM UTC
It seems like you should be able to control access to the representation separately from the primary content download.  See https://www.ptc.com/en/support/article?n=CS67396
TomU
Nov 17, 2018 11:12 PM UTC
