6-Contributor
Apr 22, 2024 11:37 AM UTC
Retrieve history of a Document
I want to retrieve maturity history and Lifecycle History of a document. How can I do this ? I did not found any endpoints in OData rest API.
avillanueva
23-Emerald II
Apr 22, 2024 1:15 PM UTC
Are you only looking to retrieve this via REST Api? This might need to move to Customization board. There are many ways to get this data via standard reporting if that is what you need.
6-Contributor
Apr 22, 2024 1:29 PM UTC
Hello, thank you for answer.  I wanna retrieve maturity history and Lifecycle History of a document via just OData rest API. I dont know about custumization board. what should ı do ?
HelesicPetr
Apr 23, 2024 8:06 AM UTC
Hi @EG_10925009
You need to use an template report RestApi to call the report inside the Windchill.
In the Windchill you need to create report template that return what you need.
ExecuteReportTemplate
Viewing the output of Report Template execution
InvokeIETask with report parameter
CS378132 - Input Parameter not provided in Query Builder Report
Windchill Reporting Resource
PetrH
