Retrieve parts related to a Document ID in WRS
  • June 5, 2025
  • 3 replies
  • 595 views
Version: Windchill 12.1
Use Case: We associate Documents to our Parts using ReferencedBy links.
Description:
If a document changes, it will show up in the ESI output under Changed Documents. The Document IDs are present here, but the DocumentLinks are not. This is because ReferencedBy links don't change even if the Document or Parts do.
How do I retrieve the Parts associated with a document using WRS?
Example output:
 "AddedECN": [
 "Description": "",
 "Number": "00011",
 "ObjectID": "OR:wt.change2.WTChangeOrder2:1709165",
 "@elementName": "ECNHeader",
 "Class": "com.ptc.windchill.esi.ChangeHeader",
 "LastChangedBy": "",
 "TargetID": "1000-1",
 "Name": "MyECN"
 "Release": [
 "Locale": "en_US",
 "Destination": "1000-1",
 "TransactionNumber": "11",
 "PrimaryObjectID": "OR:wt.change2.WTChangeOrder2",
 "@elementName": "Transaction",
 "CreatedDate": "2025-06-04 16:51:18 UTC",
 "ReleaseNumber": "10"
 "ChangedDocuments": [
 "Description": "",
 "ObjectID": "OR:wt.doc.WTDocument:1709259",
 "PreviousVersion": "A",
 "DocumentType": "WCTYPE|wt.doc.WTDocument|com.ptcmscloud.MY_TYPE$$Document",
 "Title": "",
 "Iteration": "2",
 "Name": "MyFile1",
 "Number": "0040",
 "Version": "B",
 "@elementName": "Document",
 "State": "RELEASED",
 "IsAssembly": "false",
 "Class": "com.ptc.windchill.esi.Document"
Best answer by Fadel
Not sure if something enahnced in 12.1 , on 12.0 I couldn't find anything OOTB
easiest way is to define an alias attribute on doc type to find reference parts using below mapping
masterReference^wt.doc.WTDocumentMaster~references@wt.part.WTPartReferenceLink~referencedBy^wt.part.WTPart~number
we can then query alias attribute in WRS
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
June 10, 2025
Buiꓘa
That's a great suggestion and workaround. Thanks for sharing!
Community Moderator
June 11, 2025
Hello @CB_12625553,
It looks like you have a response from a PTC Support expert. If it helped you solve your question, please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
