Nov 10, 2011 10:30 AM UTC
Retrieving a Attribute from an Object Using an Expression in a Workflow
Hi All,
I need to retrieve an attribute ("Operation") which which I have added to a Change Notice in a workflow expression - since the value of this attribute alters downstream activities.
So far I have got as far as:
wt.change2.WTChangeOrder2 co = (wt.change2.WTChangeOrder2)primaryBusinessObject;
String coOperation = ...
Also by using the above code, does it matter that I want to retrieve the attribute from a soft type of the change notice.
Any help would be great.
Toby
dsolatAnswer
May 22, 2012 9:18 AM UTC
You can try the code below as it works fine -
wt.change2.WTChangeOrder2 cm1 = (wt.change2.WTChangeOrder2) primaryBusinessObject;
wt.iba.value.IBAHolder ibaHolder1 = (wt.iba.value.IBAHolder)cm1;
ibaHolder1 =wt.iba.value.service.IBAValueHelper.service.refreshAttributeContainer(ibaHolder1, null, null, null);
wt.iba.value.DefaultAttributeContainer attributeContainer =(wt.iba.value.DefaultAttributeContainer) ibaHolder1.getAttributeContainer();
wt.iba.definition.service.StandardIBADefinitionService defService = new wt.iba.definition.service.StandardIBADefinitionService();
wt.iba.definition.litedefinition.AttributeDefDefaultView attributeDefinition = defService.getAttributeDefDefaultViewByPath("PhoneNumber"); //Here give the attribute name instead of "PhoneNumber".
wt.iba.value.litevalue.AbstractValueView svc = attributeContainer.getAttributeValues(attributeDefinition)[0];
IBAValue_PhoneNumber = svc.getLocalizedDisplayString();
Nov 10, 2011 5:57 PM UTC
It would help to learn the wt.query and wt.fc packages. Short of that, just use info engine.
public static Group test(WTObject primaryBusinessObject) throws Exception {
String instance = WTProperties.getLocalProperties().getProperty("wt.federation.ie.VMName");
IeService service = new IeService();
ObjectWebject webject = new ObjectWebject("QUERY-OBJECTS");
webject.setService(service);
webject.setParam("INSTANCE",instance);
webject.setParam("OBJECT_REF",PersistenceHelper.getObjectIdentifier(primaryBusinessObject).getStringValue());
webject.setParam("ATTRIBUTES","*");
webject.invoke();
Group group = webject.getService().getGroup();
return group;
group.getAttributeValue(0, "Operation");
p.s. Don't hardcode this inside an expression. And it has to run on the MethodServer. Your servlet engine won't like it.
22-Sapphire I
Nov 10, 2011 6:19 PM UTC
We do this very often in many workflow templates, without using webjects - just need simple Java code.
But - In 10.0, check out the new GUI-based way to do this that is available - very nice.
22-Sapphire I
Nov 10, 2011 6:21 PM UTC
Nov 16, 2011 1:53 PM UTC
Hi Mike,
Currently we are only on 9.1 (need a proE upgrade first), so will not be getting 10.0 for about another year. So if you can do it in a workflow then can you please tell me the java expression I need? Or at least where precisely I should be looking.
Also, is the Windchill Javadoc the only means of learning the packages as Matthew has suggested I do?
Toby
Nov 16, 2011 4:42 PM UTC
I know of two other ways to retrieve IBA values.
1. Would be to write your own queryspec, joining your pbo to the *value table, and joining that to the *definition table.
2. Uses your pbo's AttributeContainer, and retrieves the AttributeDefDefaultViews and AbstractValueViews.
1 is the approach we use when writing reports. 2 is the approach we use when dealing with single objects where we want to get/set values, but involves lots of code.
Mike, can you share your method?
Toby, you're kind of in a tough spot if you don't have an expert on hand. When I'm trying to figure something new out, I'll usually start with looking into how PTC does it. Knowing how they structure their packages and name their classes helps.
If you were doing something with documents, you may start by looking in the wt.doc package. There you'd find wt.doc.WTDocumentHelper.
If you were doing something with parts, you may start by looking in the wt.part package. There you'd find wt.part.WTPartHelper
If you were doing something with access control, you may start by looking in the wt.access package. There you'd find wt.access.AccessControlHelper
Beyond that, "helpers" often have "managers" or "services." So you could end up with WTDocumentHelper.service.* etc
Nov 17, 2011 12:00 PM UTC
I found this on another post (http://communities.ptc.com/message/165328😞
wt.fc.QueryResult qr = null;
wt.doc.WTDocument RCIDFDoc=((wt.doc.WTDocument)primaryBusinessObject);
ext.generic.util.IBAUtil objHelper = new
ext.generic.util.IBAUtil(RCIDFDoc);
ApplicationNum=objHelper.getIBAValue("ApplicationNum");
BusinessCategory=objHelper.getIBAValue("BusinessCategory");
EstimatedNetSales=objHelper.getIBAValue("EstimatedNetSales");
FGNum=objHelper.getIBAValue("FGNum");
I tweaked this to the following:
result = "NAY";
wt.change2.WTChangeOrder2 co =((wt.change2.WTChangeOrder2)primaryBusinessObject);
ext.generic.util.IBAUtil objHelper = new ext.generic.util.IBAUtil(co);
String selectedOption=objHelper.getIBAValue("UpdateJobs");
if (selectedOption.equals("No")) {
result = "YAY";
It came up with no errors when I first compiled it, I tested it, it failed, now when I compile it it comes up with the following error:
Checking Syntax...
/apps/ptc/Windchill_9.1/Windchill/tmp/WfExpression8906920.java:39: package ext.generic.util does not exist
2 errors
Syntax check complete.
It give anyone any ideas?
Nov 17, 2011 4:06 PM UTC
ext.generic.util.IBAUtil was something custom they created. It's not OOTB, as far as I know
Nov 17, 2011 4:08 PM UTC
I think you are right, I have seen that kind of thing referenced a number of times and it definitely is not a package in our system.
dsolat1-VisitorAnswer
May 23, 2012 9:12 AM UTC
Apologies I thought it did not work, I got an error but I think I may have made a mistake with the attribute logicID.
It is now working, thankyou!
Toby
May 23, 2012 6:25 PM UTC
If you are using 10.0 there are much simpler programmatic methods for getting and setting of IBA values -
More info can be found in the javadoc - com.ptc.core.lwc.server.LWCNormalizedObject
Here are some examples
Example usage:
CREATE
LWCNormalizedObject obj = new LWCNormalizedObject("com.acme.AcmePart",null,null);
obj.load("name","number");
obj.set("name","my name");
obj.set("number","12345");
obj.persist();
RETRIEVE
LWCNormalizedObject obj = new LWCNormalizedObject(my_persistable,null,null,null);
Object nameValue = obj.get("name");
Object numberValue = obj.get("number");
UPDATE
LWCNormalizedObject obj = new LWCNormalizedObject(my_persistable,null,Locale.US,new UpdateOperationIdentifier());
obj.load("attributeA","attribtueB");
obj.set("attributeA",new Boolean(true));
obj.set("attribtueB","PURPLE");
obj.apply();
PersistenceHelper.manager.modify(my_persistable);
May 24, 2012 9:25 AM UTC
Thanks Jeffrey, unfortunately we are stuck with 9.1 for the short-mid term. I will most likely move to this cleaner approach when we do move to 10 though.
Toby
Feb 10, 2015 8:25 PM UTC
getting this error when checking syntax
Checking Syntax...
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression831571.java:39: error: cannot find symbol
IBAValue_VM_Name= VM_Name
symbol: variable IBAValue_VM_Name
Note: C:\ptc\Windchill_10.2\Windchill\temp\WfExpression831571.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
Mar 4, 2015 12:44 PM UTC
Hi Zane,
Without seeing your full code I cannot comment too much on your error.
It seems though that you are trying to use a variable "IBAValue_VM_Name" which you have not declared anywhere in your code and this is the source of your error.
Toby
