Aug 22, 2016 7:20 AM UTC
revision conversion from letter to integer
Is there a way to display a revision as integer (1) instead of the letter (A)?
I'd like to use the Windchill parameter (PTC_WM_REVISION) on drawing.
Thanks in advance!
Aug 22, 2016 1:37 PM UTC
If your PTC_WM_REVISION is numeric, then set a relation in the drawing: DWG_REV = PTC_WM_REVISION.
Use the parameter DWG_REV in your drawing titleblock.
TomU
Aug 22, 2016 2:06 PM UTC
It sounds like Windchill is currently using letters for revisions.  To change this requires changing the versioning series.  Normally this type of change is done before Windchill is put into production as there is no good way to go back and change existing letter revisions into numbers.  Can you confirm whether or not the revision in Windchill are currently letters?
bdijkstra1-VisitorAuthor
Aug 23, 2016 11:24 AM UTC
Currently lettters are used for PTC_WM_REVISION in Windchill.
After your reply, I start thinking of a conversion in a Visual Basic program.
