Nov 4, 2015 12:34 PM UTC
RMI over HTTP
I wonder if by default, the RMI communication between the java applets and the server (RMI) is encapsulated within HTTP or not in 10.2 version
regards
Laurent
2-Explorer
Nov 4, 2015 5:12 PM UTC
I think in 10.2, the properties for RMI over HTTP is already enabled by default. So once boot.jar is pushed to client jre, if a direct connection fails, the communication will be tunneled over http
http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCAdvDepAdv_RMITunnelHTTPConfig&action=show
Thank you,
Binesh Kumar
Barry Wehmiller
Nov 4, 2015 7:35 PM UTC
RMI tunneling over HTTP is enabled by default in 10.2 M030, but not in earlier releases of 10.2. This is because JRE 8 is supported as of 10.2 M030. JRE 8 prevents applets from making direct RMI connections, so RMI tunneling over HTTP is required. See CS165748 for information on Java8 and RMI tunneling.
lvuong1-VisitorAuthor
Nov 5, 2015 9:02 AM UTC
thank you for your answer : So the RMI setup  is done automatically at client side for HTTP. but in case of HTTPS, it works also ?
and what about server side? we need to configure a property different from the default value ?
regards
Laurent
