Mar 30, 2023 8:29 AM UTC
Rouing options grayed out
Hi there,
I have the following problem, when I start as an orgadmin I create a Text Document and start the Problem report. When I look in the Problem report workflow i ve put as Change Admins I 3 participants: orgadmin, user A and user B. I sign in as user A i can see the problem report but can't approve the same as user B. I can approve only as orgadmin. For user A and B the routing options are grayed out so they can't bring any decision like Fast track approval, clarify, reassign etc... but i want also approve as user A and user B why is that not possible?
Jul 3, 2023 3:41 PM UTC
Hey Marco i've solved the problem, the solution is as follows: I deleted the organisation from the users accidently so they are not participating in a organisation so they don't have routing options shown in picture:
HelesicPetr
Mar 30, 2023 10:06 AM UTC
HI @EC_10581209
Can the users A and B finish the task?
I would suspect that the users do not have correct access to the system based on ACL definition.
PetrH
Mar 30, 2023 10:11 AM UTC
User A and B can't finish the task, but I ve put user A & B as change admins I role they can see the problem report but approval option is grayed out. User A has the Windchill advanced licence and user B has the Basic licence
HelesicPetr
Mar 30, 2023 10:16 AM UTC
Hi @EC_10581209
Have you put them to the roles on the context after the task has been created?
This can explain a lot.
If the users do not own the task that they can see in the home page, can not finish them
Only the workflow task owner can do that.
I guess that they are not part of the workflow team.
PetrH
