Apr 8, 2013 3:08 AM UTC
Run/Execute *.qml file through java code
Hi Expertes,
I would like to understand is it possible to execute/run the QML (Windchill report) through java code? I'm aware of importing/loading into windchill but i'm interested to execute the qml through java and get the response. I have tried exploring the report code but got no clue.
Manjunath Reddy
Apr 8, 2013 12:29 PM UTC
Hi Manjunath
please take a look at the webject
<ie:webject name="Generate-Report" type="OBJ">
The Generate-Report webject executes a Windchill Report Template and returns
the results as an Info*Engine group. WCAdapterGuide details out the syntax
of the webject.
HTH
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
Apr 8, 2013 12:32 PM UTC
There are supported Java APIs for this purpose as well.
See wt.query.template.ReportTemplateHelper, for instance.
Jess Holle
DarshanT1-VisitorAuthor
Apr 9, 2013 2:03 AM UTC
Hi All,
Thank you for all your suggestion and ReportTemplateHelper.convertToReader did the trick.
Manjunath Reddy
Jan 21, 2019 10:04 PM UTC
Hi Manjunath and others.
I'm also struggling with running a saved report template via java code.  Manjunath, how did you use convertToReader()?
ReportTemplateHelper class has limited Javadoc, and I don't see ANY Javadoc for ReportTemplateHelper.convertToReader()?
By guessing on the input hashmap and other parameters, I have been able to get a report to run using ReportTemplateHelper.generateTableModel(), but I can't figure out how to export it as a CSV file.
Is there any sample code that runs a report using ReportTemplateHelper and saves the results to a file?
Tim
