Run list of all Roles from WC Shell?
Rather than wait for PTC to answer a service request, anyone know how to get a list of all roles from the Windchill Shell?
EnumResourceInfo
I think it's called CutomeRoleRB
It shows the internal and GUI name for each role.
I think what you want is the command "windchill wt.fc.EnumeratedTypeUtil wt.project.Role".
That gives output like this
DESIGNER:
display = Designer
abbreviatedDisplay = Designer
fullDisplay = Designer
shortDescription = Designer role
longDescription = Designer role
comment (deprecated)= Designer role
order = 100
isDefault = false
selectable = true
stringValue = wt.project.Role.DESIGNER
enumValue = DESIGNER
Localized error message test, not an actual error:
Problem occurred trying to create "Designer" object.
lgrant16-PearlAuthor
Thanks Patrick. Any idea why some of the roles (like your example) have "Localized error..."?
It is just a test of the error message. It is not an actual error. They should all output the same test message with the relevant input (Designer in my example above).
