18-Opal
Mar 5, 2026 8:21 AM UTC
Running commands under Windchill Shell from a script
Version: Windchill 13.0
Use Case: We have an Ant build script that builds and installs a PDMLink customization package. An engineer connects to a server via Remote Desktop and runs it from within Windchill Shell. We'd like to trigger it from a CD pipeline instead.
Description:
Hello All,
I've been using Windchill Shell interactively, i.e. launching `<WT_HOME>/bin/windchill shell` and then doing everything else in a session that opens. I can't figure out how to launch something (e.g., an Ant build script) under Windchill Shell in a "headless" mode, i.e. from a script (PowerShell, a batch file, a Bash script, ...)
It sounds like a common problem and I'm sure people do it all the time, but... how?
Constantine
rhartAnswer
Mar 9, 2026 10:04 AM UTC
I've never tried to script ant but used .bat for other windchill shell commands like xconfmanager, loadfiles, running cps installer.
I think ant would be similar, for example the ant command "ant -DHTTPS_ENABLED=true -f config.xml reconfigure" might look like this?
set "ANT_BIN=%WT_HOME%\ant\bin"
call "%ANT_BIN%\ant.bat" ^
 -DHTTPS_ENABLED=true ^
@echo off
setlocal EnableExtensions EnableDelayedExpansion
REM ---- Configure Windchill home ----
set "WT_HOME=E:\ptc\Windchill_13.0\Windchill"
set "WC_BIN=%WT_HOME%\bin"
REM ---- Logging ----
set "LOG=%WT_HOME%\logs\windchill_shell_command.log"
echo.>>"%LOG%"
echo ==================================================>>"%LOG%"
echo %DATE% %TIME% - Starting windchill shell command >>"%LOG%"
echo WT_HOME=%WT_HOME%>>"%LOG%"
REM ---- pre-requisite checks ----
if not exist "%WC_BIN%\setvars.bat" (
 echo ERROR: Missing "%WC_BIN%\setvars.bat"
 echo ERROR: Missing "%WC_BIN%\setvars.bat">>"%LOG%"
 exit /b 10
if not exist "%WC_BIN%\xconfmanager.bat" (
 echo ERROR: Missing "%WC_BIN%\xconfmanager.bat"
 echo ERROR: Missing "%WC_BIN%\xconfmanager.bat">>"%LOG%"
 exit /b 11
pushd "%WC_BIN%" || (
 echo ERROR: Cannot cd to "%WC_BIN%"
 echo ERROR: Cannot cd to "%WC_BIN%">>"%LOG%"
 exit /b 12
REM ---- Start the environment ----
call "%WC_BIN%\setvars.bat" >>"%LOG%" 2>&1
set "RC=%ERRORLEVEL%"
if not "%RC%"=="0" (
 echo ERROR: setvars.bat failed with exit code %RC%
 echo ERROR: setvars.bat failed with exit code %RC%>>"%LOG%"
 popd
 exit /b %RC%
REM ---- RUN WINDCHILL SHELL COMMANDS ----
echo Running: windchill shell command
echo Running: windchill shell command>>"%LOG%"
REM ---- Run an xconfmanager command
REM call "%WC_BIN%\xconfmanager.bat" -p >>"%LOG%" 2>&1
REM set "RC=%ERRORLEVEL%"
REM ---- Run a loadfile command like: windchill wt.load.util.CSV2XML -delimiter ~ -input test.csv ----
REM call "%WC_BIN%\windchill.exe" wt.load.util.CSV2XML ^
REM -delimiter ~ ^
REM -input "doc_migrations.csv" ^
REM >>"%LOG%" 2>&1
REM ---- Run a loadfile command like: windchill wt.load.LoadFromFile -d E:\ptc\Windchill_10.2\Windchill\src\loadFiles\test.xml -u wcadmin -p <pass> -CONT_PATH "/wt.inf.container.OrgContainer=<org>/wt.pdmlink.PDMLinkProduct=<product>"
call "%WC_BIN%\windchill.exe" wt.load.LoadFromFile ^
 -d "E:\ptc\Windchill_13.0\Windchill\src\loadFiles\doc_migrations.xml" ^
 -u wcadmin ^
 -p <pass> ^
 -CONT_PATH "/wt.inf.container.OrgContainer=<org>/wt.pdmlink.PDMLinkProduct=<product>" ^
 >>"%LOG%" 2>&1
REM ---- Run xconfmanager -p ----
REM set "WT_HOME=E:\ptc\Windchill_13.0\Windchill"
REM set "WC_BIN=%WT_HOME%\bin"
REM Optional log
REM set "LOG=%WT_HOME%\logs\cps_install.log"
REM ---- Run java
REM echo Running java safe area install... >>"%LOG%"
REM java -jar "%JAR%" --completeSafeAreaInstall "%WT_HOME%" >>"%LOG%" 2>&1
echo Running: windchill shell command done
echo Running: windchill shell command done>>"%LOG%"
popd
 echo ERROR: windchill shell command failed with exit code %RC%
 echo ERROR: windchill shell command failed with exit code %RC%>>"%LOG%"
 exit /b %RC%
echo Success: windchill shell command completed.
echo Success: windchill shell command completed.>>"%LOG%"
exit /b 0
avillanueva
23-Emerald II
Mar 5, 2026 12:28 PM UTC
Not an expert but I think you need to have a runner installed on the Windchill server connected to Github. It can then be listening for requests to run your scripts.
rhart16-PearlAnswer
@echo off
echo.>>"%LOG%"
 exit /b 10
 exit /b 11
 exit /b 12
 popd
 exit /b %RC%
REM -delimiter ~ ^
REM >>"%LOG%" 2>&1
 -u wcadmin ^
 -p <pass> ^
 >>"%LOG%" 2>&1
REM Optional log
REM ---- Run java
popd
 exit /b %RC%
exit /b 0
18-Opal
Mar 12, 2026 3:04 PM UTC
Thanks @rhart , that's exactly what I was looking for!
So all I needed to do in my script was to set WT_HOME and call setvars.bat. It works! Demystifying windchill shell 😁
Constantine
Emeritus
Mar 12, 2026 10:02 AM UTC
Hello @Constantine,
It looks like you have some responses from some community experts. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
