May 1, 2019 8:02 PM UTC
Save as STEP file from within common space.
Can I create a STEP file of a part or assembly, with it checked in from common space only ?
TomU
May 1, 2019 8:24 PM UTC
No.  You have two options:
  1. Add the object to a workspace, open in Creo (or 3rd party CAD), and save-as to a STEP file.
  2. Have Windchill generate a STEP file during publishing.  (It performs the same steps as above, but on the CAD worker machine.)
dpasholk1-VisitorAuthor
May 2, 2019 12:49 PM UTC
Can I choose to create a selected part to be published as a STEP file. I have my change notice ready to submit and want to publish the STEP file for only this notice. Not for every notice that comes next. Are there any setting to do this selectively?
Your help is most welcome.
Dan Pasholk
TomU
May 2, 2019 1:16 PM UTC
It depends entirely on how your administrators have your system configured.
22-Sapphire I
May 2, 2019 8:14 PM UTC
We've had this in place for ~ 2 years with great success.
Publish rules govern what gets created by publishing for user request vs. check in, schedule, or workflow.  We generate STEP and IGES, and also STL for Creo (not for SolidWorks), rename the resulting files to include the version (e.g. 2623465_prt_A2.stp), and show on /Content/Attachments.
Any user can command the system to generate these files, and then download using only a browser.
2-Explorer
May 3, 2019 3:39 PM UTC
@MikeLockwood
We also have the post-publish rules, and produce STEP from models and PDF,DXF, and DWG for 2d files. Works really well for us.
How do you go about "rename the resulting files to include the version"  That would be great and it's something our Partner doesn't know how to do.
James - Windchill 11.0, Inventor 2018
TomU
May 3, 2019 3:41 PM UTC
These two articles explain how to rename the files after publishing:
https://www.ptc.com/en/support/article?n=CS216668
https://www.ptc.com/en/support/article?n=CS252900
Feb 26, 2020 4:31 PM UTC
I can create a STEP 242 file of an assembly and save it to my working directory.
How can I get to my workspace? To save it into common space? I am trying out
the 242 standard to have an embedded title block.
Thank you for any help. Dan
2-Explorer
Feb 26, 2020 6:47 PM UTC
@dpasholk
I don't think you can.  At a former company, we attached STEP files as attachments on the Content tab.
James
