Jun 7, 2024 7:41 AM UTC
saveas - Collected Object exclude
Hi Guys
I found this our PTC Community can we do the same thing for the library component?
AJ
PTC Community
I'm willing to share a small secret  The following solution is not really nice, but it works.
Put following file to the WTSafeArea
%WT_HOME%\codebase\templates\uwgm\cadx\saveas\saveas.js
Afterwards open it, search the two methods and add following code:
function updateItemsWithInitialValue(tableid, columnid, rowsToUseFunc, setterFunc, setterArgObj) {
 var itemsArray = getRowDataForJSTable(tableid);
 var l = itemsArray.length;
 for ( var i = 0; i < l; i++) {
 var item = itemsArray[i];
 var FieldValue = item.getAttr('oirConstraints');
 var isNamePreGenerated = false;
 if (FieldValue & NAME_PRE_GENERATED_ATTR)
 isNamePreGenerated = true;
 // 14219836: To avoid overwriting the name, org, number when pregenerated constraint is set.
 if (!(isNamePreGenerated && columnid == newNameColumn)) {
 if (rowsToUseFunc(item))
 setterFunc(item, columnid, setterArgObj);
		//----custom-code----
		var FieldValue2 = item.getAttr('objCadModelName');
		if(FieldValue2.endsWith('.frm')){
			item.setExcluded(true, true);
		//----custom-code-END----
function updateIncrementallyAddedItemsWithInitialValue(tableid, columnid, newItems, setterFunc, setterArgObj) {
 var itemsArray = newItems;
 setterFunc(itemsArray[i], columnid, setterArgObj);
After that, the client browser cache needs to be deleted.
The attached movie is from Windchill 10.2, but it works also in 11.0 and 11.1.
Since the Save-As Wizard did get a small redesign in 11.2 it's possible that the code isn't working anymore.
Emeritus
Jun 13, 2024 10:11 AM UTC
Hi @Amirtharaj_K,
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
