Nov 12, 2021 7:26 AM UTC
Saving an old version/iteration of a part as a new version (without Creo)
Hello everyone,
Is there any way to save an old version or iteration of a part as a new version in Windchill without using Creo Parametric?
I have a part with latest version of C.1 and I'd like to return back to version B.1 without deleting version C. I thought that I could revise the part to version D and somehow copy the B.1 version over the D.0 but I can't figure how to do that in Windchill.
I found this article which describes how to do exactly that with Creo Parametric:
https://www.ptc.com/en/support/article/CS189560
But I would prefer a method for doing it in Windchill. Is it even possible?
Nov 12, 2021 9:56 AM UTC
This article seems describe what you need: https://www.ptc.com/en/support/article/CS100514
You may need to change preferences.
  • Navigate to Site (or specific Context) > Utilities > Preference Management > Revise
  • Set value Yes for the preference ​Allow revise of non-latest revisions
  • Browse to the latest iteration of a previous revision from Object's History tab
  • Actions > Revise
I hope this helps.
  • Actions > Revise
I hope this helps.
N-Pyn15-MoonstoneAuthor
Nov 12, 2021 10:26 AM UTC
Thank you, this was just what I was looking for!
So the solution was to set Allow revise of non-latest revisions setting to Yes and then I could revise the A.1 version, which creates a revision D.0 with the data from A.1.
Nov 12, 2021 7:37 PM UTC
Lets clarify some information.
Windchill iterations, A.x, B.x, 0.x, where x is the iteration always start at 1, not 0.
When revising a file, lets, say C.5 to D.1, all of the X.1 revisions are equivalent to the prior version, last iteration. C.5 is equal to D.1.
Using the Allow Revise of Non-latest revision will allow you to take your A.5 and make it D.1, assuming you have a B and C version.
