saving issue
When saving an assembly, often times Creo will ask me “Do I want to save/continue/make read only/etc” parts that have really not been intentionally modified. When I indicate “Make Read Only”, I get the message “[filename] could not be saved to the workspace”. Then if I save a second time, the assembly is saved “[filename] has been saved”.
Is this something we are doing wrong that makes us have to save twice? Some procedure we need to correct? A setting in the config that needs adjusting? Creo 3.0 F000 Windchill 10.2 M22
Thanks in advance,
Herb Spaulding
Miller Industries
