Apr 6, 2015 9:01 PM UTC
Search for BOM - Windchill PDMLink is not available
We are in the process of configuring WPA an I've been able to load data from Windchill into WPA through the synchronize command. I can then go to WPA and search on both the Supplier and Company parts and find the data.
When I do a Search for BOM and select BOM Source to be Windchill PDMLink and specify a BOM number that resides in PDMLink and click search, it returns a "Windchill PDMLink is not available." error message.
I'm assuming that I have a configuration not set correctly to go back and search Windchill for the BOM. Any idea what I may have missed?
Apr 15, 2015 6:51 PM UTC
When Windchill is not available, you can check the following file to make sure your settings are correct.
On the WPA server, open file <Product_Analytics>\virgo-server\config\propsloader\services\com.ptc.insight.connectors.windchill.properties
Edit the following properties, and save the file.
  1. com.ptc.insight.connectors.windchill.address=learn-prod-demo
  2. com.ptc.insight.connectors.windchill.username=wcadmin
  3. com.ptc.insight.connectors.windchill.password=ptc
  4. com.ptc.insight.connectors.windchill.passwordEncrypted=false
  5. com.ptc.insight.connectors.windchill.protocol=http
  6. com.ptc.insight.connectors.windchill.webappID=Windchill
Restart WPA
