Aug 16, 2024 10:09 AM UTC
Search in Windchill folder
I am probably missing something quite simple - I can't figure out a way to search within a certain folder and the subfolders in WC. In other words, if I have the WC context with the following structure:
Product1 Context
 - Folder 1
 - Folder 2
  --- Subfolder A
  --- Subfolder B
 - Folder 3
I want to run a search in Folder 2 and include files in Subfolers A and B in search results.
It seems that searching in folders has been added in WC 10. When I go to WC -> Quick links > Help > Windchill Help Centre ,  it pops up a page called "Welcome to the Windchill 12.1.2.0 Help Center", so I assume I am using V12.1.2.0 and I should have this functionality.
From some searches online, I found these pages that may be relevant:
https://support.ptc.com/help/windchill/plus/r12.0.2.0/en/index.html#page/Windchill_Help_Center/LclSrchSearchInContextBP.html
https://www.ptc.com/en/support/article/CS22115
Based on the first link, I should be able to have this search window somewhere:
However, whenever I click on menu item "Folders" in the Context menu, I am taken to a page "Folder Contents" and not "Folders". Can somebody please advice where am I going wrong?
Thank you!
HelesicPetr
Aug 20, 2024 6:43 AM UTC
Hi @Ben8
The point is that the folder tree is shown only in a standalone browser in folders.
If you access to a windchill from a Creo, then the folder tree is not shown.
PetrH
avillanueva
23-Emerald II
Aug 19, 2024 1:23 PM UTC
Sry, not quite following. There are a few ways and locations to start a search. The image above should be a search for items in the selected folder from the folder tree ( and I would assume folders below that ). Mine defaulted to a keyword search but looks like it added the starting folder to "My Favorite Contexts". I had no idea I could add a folder. From there, I can change this into a advanced search if I did not want to use a keyword but rather some other attributes.
As far as the version, I remember back in WC 10, I had help installed locally. After that version, help was redirected to ptc.com so if you did not have it installed, I can see if defaulting to latest version. I doubt WC10 help is available online anymore. If you are looking for version differences, I suggest you look at the what's new docs and see if there was an enhancement that was added which could cause a difference in what you are seeing in the help as opposed to your version.
This is what you see in 12.02. A folder tree is on left and the Folder Contents are on the right in a split table.
HelesicPetr
Hi @Ben8
PetrH
Ben813-AquamarineAuthor
Aug 21, 2024 3:32 PM UTC
Thank you, i didn't realize the browser in Creo would be missing such a function. Works well on external browser.
