joe_morton
Jun 25, 2021 7:29 PM UTC
SearchCondition for ManagedBaseline
I'm working on some code in a workflow and I want to be able to query baselines that meet certain conditions. When I use syntax like the below, the workflow goes to an "aborted" state with no indication as to why.  How would I query baselines?
wt.query.SearchCondition sc = new wt.query.SearchCondition(wt.vc.baseline.ManagedBaseline.class, "lifeCycleState", wt.query.SearchCondition.EQUAL, "Approved", false);
d_grahamAnswer
18-Opal
Jun 28, 2021 8:00 PM UTC
Joe,
So, you're trying to query based on a case insensitive value of the lifecycle state.
You need to replace "lifeCycleState" with:
 "state.state"
Hope this helps
David
d_graham18-OpalAnswer
18-Opal
Joe,
 "state.state"
Hope this helps
David
joe_morton
Jun 30, 2021 6:01 PM UTC
Thanks!
I found another way to get what I needed, but I tested the code you gave, and it didn't cause the workflow to abort.
Thanks for the help!
