18-Opal
Feb 11, 2016 5:08 PM UTC
Searching PDMLink / Windchill
Any ideas on how to improve the breath of searching abilities in PDMLink?  Most particularly:
  1. At minimum, PDMLink should be able to search every area that a user can input information in PDMLink, but apparently it doesn't?!  For example, currently it doesn't search Change notice attachments, nor even the description that the user types in the PDMLink description field!  In addition, there are some areas of CAD objects that it has not searched but perhaps someone else can remember which ones.
  2. This may be a stretch, but is there an easy way to get PDMLink to index and search drawing content (that are not attributes...the text actually on the drawing)?
Thanks! Lawrence
2-Explorer
Feb 11, 2016 6:20 PM UTC
Do you have Solr installed?  That is the indexing tool that will allow keyword search to search content.
BTW. What version of Windchill are you using?
LawrenceS18-OpalAuthor
18-Opal
Feb 11, 2016 9:13 PM UTC
Yes, we use Solr, and it is setup to be used to index everything else in PDMLink, but not the stuff I described above.
Also, our drawings are published to HPGL because if we published them to pdf we had a few problems.
We are on WC 10.1
20-Turquoise
Feb 11, 2016 10:42 PM UTC
You can configure solr to index the text in (Creo Parametric) drawings by setting indexable to true for the DRW formatName.  See:
http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=WCCG_Serv_DataFormats_AddUpdateDataFormats&action=show
Basically you are going to use:
  • windchill wt.content.DataFormatUtil -list
    • to list the current formatName's and their information
  • windchill wt.content.DataFormatUtil -update
    • to update the DRW formatName and set indexable=true
after this you will need to run the bulk indexer ( windchill wt.index.BulkIndexTool )  in order to get the drawings indexed - might take a while depending on how many you have
Trying this on a test server is always good...
18-Opal
Feb 11, 2016 10:45 PM UTC
, Thanks for posting this method/suggestion, I will look into this and post back...
Feb 12, 2016 12:18 AM UTC
Another description of how to do this is available here "Add CAD Data to Windchill Index Search": http://support.ptc.com/cs/help/windchill_hc/wc110_hc/WCSysAdminIndexSearch_SetUpWCIndexSearchIndexCADPart.html
Also "Specify MIME Types for Content Indexing":
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/WCSysAdminIndexSearchFileContentIndexing.html
See the sections:
  • "Add a MIME Type"
  • "Verify that a MIME Type is Indexable"
Regarding Change Notice attachments -
Yes, it appears that the attachment description field is not indexed OOTB. However, the attachment content and file names should be indexed, and keyword-searchable. The caveat is that the Change Notice is listed in the search results -- not the attachment.
