avillanueva
23-Emerald II
May 23, 2014 6:49 PM UTC
Security Labels and iterations
Did I miss something? If I apply a security label, why would it tag to the iteration? Why not to the version or master item? - PDMLink 9.1
You do not need to check out the item but its odd that you can go to a previous iteration and it shows that it was not applied.
Antonio Villanueva - Sr. Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Road, Danbury, CT 06804
Tel: +1 203 797 5682
antonio.villanueva@utas.utc.com<">mailto:antonio.villanueva@utas.utc.com> www.utcaerospacesystems.com
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
Jul 21, 2015 7:02 PM UTC
In 10.2 M030 a configuration option has been introduced where a security label value change can be applied to all versions.
11-Garnet
Oct 20, 2015 3:45 PM UTC
Steve,
Got a related question. I am new to this topic.
I am interested to know how security label values are managed across iterations of a given version. Whether system allows user to set different values on different iterations (like A.1 vs A.2)?.
It is more of technical capability check than thinking about what values it brings.
Ayyappan
Oct 20, 2015 3:56 PM UTC
Yes.  Security Label values can be set differently for different iterations and versions of the same object.  In 10.2 M030 we introduced a configuration option where when setting the value for any version it would set all versions to the same value.
