3-Newcomer
Aug 10, 2026 7:47 AM UTC
Sending of the Windchill Performance Advisor report to PTC has failed
We are experiencing an issue with Windchill Performance Advisor data transmission.
The system generated the following notification:
Sending of the Windchill Performance Advisor report to PTC has failed due to:
Network Failure - check the background method server logs.
Event Time: 8/8/26, 7:40 AM
Server URL:
http://windchill.ni.corp.natinst.com/Windchill
Performance Advisor Page:
http://windchill.ni.corp.natinst.com/Windchill/apps/wa/templates/performanceAdvisorMainPage.jsp
Additionally, when executing Test Transport from the Performance Advisor UI, the following error is displayed:
Test Transport failed. Unable to connect to file receiver please try after sometime
MS Logs:
2026-08-08 02:32:37,178 ERROR [ajp-nio-127.0.0.1-8010-exec-4] com.ptc.wa.rest.services.impl.WAServiceImpl wcadmin - ***Exception occurred while sending the report through HTTP mechanism com.ptc.wa.WAException: java.io.IOException: HTTP(S) response code: 406; message: Not Acceptable
However, our investigation indicates that this is likely not a network connectivity issue:
The Windchill server can successfully resolve and reach support.ptc.com.
HTTPS communication is working.
Manual POST requests to https://support.ptc.com/apps/pa4all/Validate.jsp return a valid response from the PTC server.
No SSL, DNS, timeout, or connection errors are observed.
MarcoTosin
Aug 24, 2026 7:57 AM UTC
Hi Catalina,
today, when I returned from vacation, I found the same error mentioned in this thread in the emails I received during that time.
The problem lasted three days and then went away, more or less at the same time this issue was reported.
I think the error was on PTC’s side—they’ve since resolved the issue—and not on the user’s side.
Marco
Catalina
Community Manager
Aug 21, 2026 3:22 PM UTC
Hi ​@PH_14392337
Thank you for your question. 
Catalina | PTC Community Manager
MarcoTosin
Hi Catalina,
Marco
