Jun 23, 2016 12:28 PM UTC
Sequence Generation with MS SQL
Hi guys,
I recently started with Windchill 10.2 and I have the following problem:
I need a new sequence generator that will generate the sequence from 000001 to 999999. I am using the following sql script:
CREATE TABLE wt_sequence_WTTESTID (dummy CHAR(1), value BIGINT IDENTITY(000001, 1))
go
CREATE PROCEDURE wt_get_next_sequence_WTTESTID @returnValue BIGINT OUTPUT
AS
INSERT wt_sequence_WTTESTID (dummy) VALUES ('x')
SELECT @returnValue = SCOPE_IDENTITY()
go
The question is how can I set the upper limit to 999999?
Alex
