Aug 4, 2023 9:26 AM UTC
Server error: Cannot retrieve family table neutral data
when I open the file .asm refers to an old project (inserted in the windchill system two years ago)
there is a conflict Server error: Cannot retrieve family table neutral data.
Please could you send me a solution to this problem?
MarcoTosin
Aug 4, 2023 9:46 AM UTC
You can start researching a solution to your problem using the knowledge base of PTC support.
This is what comes out as a result using the error message you wrote
https://www.ptc.com/en/support/search/#q=%22Server%20error%3A%20Cannot%20retrieve%20family%20table%20neutral%20data%22
Marco
Aug 4, 2023 9:52 AM UTC
Thank you Marco
I'll try to follow your kind indication
