Dec 19, 2017 2:07 PM UTC
Server manager hangs on startup, MethodServer fails to launch
Hello All
when i entred "windchill start" in the CMD, server manager will stop at this stage and method server will never start , what could be the reason ?
Dec 19, 2017 2:55 PM UTC
Is Windchill DS started first?
Is Apache/the Web server started second?
Are your vaults enabled?
Any other log file messsages?
Dec 19, 2017 4:30 PM UTC
Hello Ben
Yes, Windchill DS started first and  Apache/the Web server started second?
how to check if vaults are enebled? i am thring to launch in my own PC
I foud a releated article for the exact same issue , but could not understand how to check in host file , i am attaching the host file here , also could not how to check cause 2 mentioned in this article?
https://www.ptc.com/en/support/article?n=CS125275
Resolution given in this article
Regards
Dec 19, 2017 3:35 PM UTC
Add some logs :
in WINDCHILL_HOME/codebase/WEB-INF/log4jServerManager.properties.
log4j.logger.wt.manager.ServerLauncher=DEBUG
and look in ServerManagers log file. Look for the command and parameters used to launch the MS
Dec 19, 2017 4:20 PM UTC
Hello olivier
Attaching  2 log files "log4jServerManager.properties" and "ServerManager-1712192006-2308-log4j"
Regards
Dec 19, 2017 4:45 PM UTC
This is strange, I don't see any logs.
It's log4jMethodServer.properties in the zip file, not log4jServerManager.properties, so...
Dec 21, 2017 11:03 AM UTC
Check the connection to your database.
Dec 21, 2017 4:30 PM UTC
database is conneting ,
is this the right way to check ?
Regards
Dec 22, 2017 7:29 AM UTC
Check the db properties and the connection by your db user.
