Jul 4, 2024 9:14 AM UTC
Service impact attribute needs to be removed from the multipart creation window
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
Service impact attribute is getting displayed in the muti part creation window
Community Moderator
Jul 8, 2024 4:04 PM UTC
Hi @RC_10659261,
Thank you for your question.
Anurag
joe_morton
Jul 8, 2024 7:46 PM UTC
Is the multi part creation window working differently than when creating a single part?
The multi part creation window allows for different views. The admin can customize the default view as needed, or even create new views. If the attribute is required and a default is not set, it may cause errors if the attribute is not visible.
