Dec 31, 2014 7:22 AM UTC
Set Minimum character for Global Search
We have been facing very high impact on performance due to search producing results more than 20000 objects.
I would like to know is there a way to set the minimum number of characters to be used for the global search.
The present scenario is searching with a*, t* etc., - I need atleast 3-4 characters to be used for the search.
Checking with PTC -
The preference below is to have minimum characters for the participant search.
com.ptc.netmarkets.participantPicker.requiredCharacterSearch
Default: -1
Synopsis: This property controls whether the participant picker requires a specific number of characters before executing.
Description: If the property is set to -1 (by default), then the participant picker will execute a search regardless of the number of characters in any of the fields. Depending on the number of participants in the system, an unbound search could cause a major performance delay. Changing this value to an integer will specify the number of characters required in at least one field before executing the search.
Jan 5, 2015 6:09 AM UTC
The mentioned property will work only for a participant picker. Participant picker is used for searching users only. I believe, in your case you are using the top right hand global search, which can search across various objects.
There are various things that come to my mind as a solution/ workaround for your issue:
1. Are you doing an 'All Type' search with a*,t* as the criteria ? Is it possible for you to narrow down your search for specific objects ? For ex: Part and Document etc.
2. There are properties that let you have a predefinined number of rows to be returned. If the result set exceeds the number that is specified, a banner message is shown indicating that the search result more results that the limit.Following are the properties to be set in db.proeprties:
wt.pom.paging.snapshotQueryLimit
wt.pom.queryLimit
By default, these are set to -1 which indicates there is no limit to the result set returned. There are a few well written articles at PTC tech support to explain these proeprties in details.
3. From what I understand, you would like to restirict search if the number of characters entered are less tahn 3 or 4. Customization will be required to achieve this.
The Global Search is rendered using Twin Trigger field which is an EXTJS component. The rendering code can be found at -
<WT_HOME>\codebase\netmarkets\javascript\util\jsfrags\globalSearch.jsfrag
The line would look something like - twinField = new Ext.form.TwinTriggerField({ ....
There is a js function is globalSearch.jsfrag viz. loadSearch(...). This too might require a change.
Note: This customization will not work on the search page that is available through the navigator.
-Malavika
taruchamy12-AmethystAuthor
Jan 5, 2015 6:47 AM UTC
Hi Malavika,
Thanks for the reply.
I need to use it for both "top right hand global search" and the Navigator search.
And yes, we are resticting the search towards ONE specific object type - Not even two.
I have already set to 10000 for pom query limit - Reducing this will have issue in displaying the where used objects - Especially for our standard objects [Display will be blank on where used report].
Though it will not work on navigation search, I can try customizing it with your suggestion - Can you able to provide clear steps ?
Murthi
Jan 5, 2015 7:06 AM UTC
In that case I would recommend you go through the file I mentioned above and dig through the code there. globalSearch.jsfrag should be used to customize the global search.
Whereas, to cutomize the search page would be a little more effort. One has to have the following considerations :
1. Should the search be restiricted based on number of characters only for the keyword filed ? or would you need similar restiriction on all the attributes ?
2. Would you want a similar restiriction in case of newly introduced IBA's ?
The rendering for the navigator search page happens from <WT_HOME>\codebase\netmarkets\jsp\searchcommonSearch.jsp.
-Malavika
