Mar 16, 2015 12:30 PM UTC
Set or change window size
Does anyone know where we can control the size of a popup window? When we are in a library, and we need to move the object to a different folder or context, we right click on the object and select "Move". Then, under the "New Location" column, we click the folder icon to choose a new folder or context. We ALWAYS have to expand the "Set Location" window to see all of the options. We would like to be able to have it open already expanded. This is on WIndchill 10.2.
2-Explorer
Mar 16, 2015 8:23 PM UTC
Hi Tim,
You should be able to modify this in \Windchill\codebase\action.properties.
There are urlinfo properties specific to specific actions that controls the
pop up window size here.
Binesh
Barry Wehmiller International
On Mon, Mar 16, 2015 at 7:30 AM, Tim Gudobba <->
tgudobba14-AlexandriteAuthor
Mar 17, 2015 12:02 PM UTC
Binesh,
Do you know which setting applies to the Set Location?
