Jun 30, 2016 3:03 AM UTC
Set Revision Scheme to be -.1 , A , A.1 ... B, B.1
I am trying to setup a revision scheme to be:
-.1 ... A, A.1 ... B, B.1
I'm almost there but what I currently have is:
-1 ... A.0 , A.1 ... B.0, B.1
I am setting: wt.series.IntegerSeries.min = 0 but I rather that just be nothing and then iterate to 1.. How can I get this to work?
Jun 30, 2016 1:29 PM UTC
I don't think that is possible because the .x is the iteration and it always starts at 1.
For your drawing or whatever, use the wm_ptc_revision, which will only be the A, B, etc.
TomU
Jun 30, 2016 2:38 PM UTC
Ditto to what Ben said.  You can choose where the iterations will start (0, 1, etc.), but you can't not have any iteration at all.
22-Sapphire I
Jun 30, 2016 3:00 PM UTC
Ditto to what others said.  Can never have the Iteration blank.
May want to put some energy into managing the various places where Revision, Iteration, Version can be used / displayed (e.g. in drawing table cells, reports, table columns, etc.).  Can show either "A" or "A.2" as needed.
