Dec 27, 2019 1:02 AM UTC
Set the number of method servers to start
Hope someone sees this.  I'm in the middle of a production upgrade and because the production server is much larger than the test server, it decided it needed 7 method servers instead of one and so the upgrade manager is failing when it tries to start up Windchill since it has too many method servers.  What is the option to set the number of method servers starting using xconfmanager?
Dec 27, 2019 2:14 AM UTC
so embarrassing, but I had a typo somewhere else in those properties.
Dec 27, 2019 1:48 AM UTC
It isn't the method server but the administrator "wcadmin" login.  Even though it worked before I started the upgrade, the password isn't working now and it worked during the tests that I ran.
BrianToussaint19-TanzaniteAuthorAnswer
22-Sapphire I
Jan 2, 2020 4:46 PM UTC
One good reason to always set these using WCA rather than changing the property directly.
Jan 2, 2020 4:52 PM UTC
@MikeLockwood, I didn't actually change that property.  It was one of the properties in the Upgrade Manager that I typed wrong.  It was with one of the ou's.  The wca gave me 7 method servers and 1 background server.
22-Sapphire I
Jan 2, 2020 4:55 PM UTC
Interesting...
I've done many dozens of upgrades / rehearsals and don't recall anywhere in the UI where the number of method servers is called out.
More to learn every day.
TomU
Jan 2, 2020 5:16 PM UTC
I know you found the root issue, but here are the properties to control the number of method servers:
  • xconfmanager -s "wt.manager.monitor.services=MethodServer" -t codebase/wt.properties -p
  • xconfmanager -s "wt.manager.monitor.start.MethodServer=1" -t codebase/wt.properties -p
  • xconfmanager -s wt.queue.executeQueues=true -t codebase/wt.properties -p
Some related KB articles:
