May 25, 2015 6:49 AM UTC
Set version of a part from another part using code
Hi All,
I need to set the version of a part same as version of another part.
For eg:
Current Version for PART B = 1.1.
Case 1: PART A has version = 1.3 then PART B version = 1.3
Case 2: PART A has version = 2.1 then PART B version = 2.1
In Case 1, I need to change the iteration only. I want to set the iteration without checkout. Is it possible??
Regards
Sudeep
May 26, 2015 2:59 PM UTC
There is no menu option to set iteration. You can only increment it by doing a check out/check in.
The bigger question is WHY?
What does having the same iteration do for you?
If you study PTC training documentation you will see that revision.iteration 4.4 is the same as 5.1 after doing a revise to the file. Only when you get to 5.2 is the file different than 4.4.
