Apr 13, 2023 4:00 PM UTC
SetGlobalID api does not work
We have a problem in our database from windchill 12. Normally all 3D EPMDocuments shoud have a globalID(sysid) in the DB, but many of them get a "null" value now.
There is an api to get the globalid --> wt.epm.EPMDocumentMaster.getGlobalID()
this api works fine
There is also an api to set the globalid --> wt.epm.EPMDocumentMaster.setGlobalID()
this api gives me an error.
Exception:
javax.servlet.ServletException: GlobalID cannot be modified for persistent master: Assembly - CAD1000474015.sdcc
Is there a possible solution for this? Is there a workaround for this and make the master not persistent for a few seconds until it's changed?
ps: the sysid is something from creo elements/direct modeling
Sep 3, 2025 2:47 PM UTC
Hi @rvanveerdeghem
We faced the same issue and resolved it using custom code. There is no Windchill API as this table column is not meant to be changed unless from Creo element.
