Oct 19, 2011 11:26 AM UTC
Setting "Autoselect Folder" as default location for new documents
Hi All,
I have created a new soft type of a document which is for requests of various types. I have set up an OIR so that it is created in a certain folder. The only problem is the user has to select the "Autoselect Folder" option under the location when they are creating a document of this type. Is there any way to make it so that they do not have the option and it is automatically created in the folder I have specified?
Toby
22-Sapphire I
Oct 19, 2011 3:00 PM UTC
You can manipulate in the OIR constraints:
- What a user sees
- What the system automatically does for folder assignment
See PTC's details in on-line help about OIRs
22-Sapphire I
- What a user sees
Mar 7, 2014 2:15 PM UTC
Hi Mike
Please could you point me in the right direction to find the online help you refer to?
If you have a link to the page that would be great as I am struggling to locate the information needed to manipulate the OIR constraint to set autoselect folder as the default
Many Thanks
Mar 10, 2014 1:38 PM UTC
Hi, Kelly,
I believe you can find the information you're looking for in the Windchill Help Center. For more information about OIRs, you could start with this topic: http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=ObjRulesChp_Intro&action=show.
For information about customizing attribute display (e.g., the UI behavior of the Location attribute), check the Attribute Customization topic: http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspxid=WCCG_UICust_PresentInfoUI_AttributeHandle&action=show
I hope you find this information helpful, and I'll welcome any feedback.
Jane
Jane Zupfer
VP, Enterprise Products Publications
E -
PTC.com
Jul 29, 2014 3:10 PM UTC
You comment the below lines in OIR for that object type:
<!-- <AttrConstraint
id="folder.id"
algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints"
ignore="false"
force="false"
final="false">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue">
</Value>
</AttrConstraint>
Add new Lines as below:
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetRendererConstraint">
<Arg>SelectGeneratedFolderByDefault</Arg>
</Value>
</AttrConstraint>
Make the chnages in Default folder path and add your required path as below:
<Arg>/Default/<Folder_Name></Arg>
I have done it for Promotion request and it worked without any issue.
Apr 2, 2015 5:55 PM UTC
Devidas,
I'd like to do exactly what you've done for the Promotion Request, however I do not know where or how to get to the file/setting where I'd add in the additional code. Could you describe how I get there?
Marc
Apr 2, 2015 6:59 PM UTC
You need to use the site/org admin utilities and edit the OIR rule for the setting you want to change.
