prerev_kompan
Aug 13, 2026 12:55 PM UTC
Show BOM based on selection of View?
I am using Windchill PDMLink Release 13.1 and Datecode with CPS 13.1.2.9 Is it possible to create an overloaded Part structure and then use Views to show a correct BOM? Generally, we have a panel attached with 4 connectors. Based on the material it will be connected to, the connector and screws will change. (Each structure SHOULD have it's own product number, but historically it has been handled otherwise.)
BryanKAnswer
Aug 17, 2026 9:55 PM UTC
Have you looked at Filters? you can/could achieve this with attribute filters.
BryanK17-PeridotAnswer
prerev_kompan
Aug 18, 2026 6:05 AM UTC
Yes, Filters are definitely a possible way. I’m looking into it.
joe_morton
Aug 19, 2026 1:51 PM UTC
More complex, but consider looking into Options and Variants. That’s Windchill’s intended tool for managing overloaded BOMs
