8-Gravel
Feb 5, 2022 8:58 PM UTC
Show Component Sheet Number in Repeat Region
Is there a repeat region parameter to show what sheet an assembly component is on?
So, basically I will have the main assembly on sheet 1 then all sub-assemblies and components of the main assembly will be on other sheets. I would like to have a table cell of the repeat region on sheet 1 to show what sheet the assembly components are on. Is this even possible?
