3-Newcomer
SMTPAddressFailedException: 452 4.5.3 Too many recipients
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS19 系统的BG里,出现了大量的:2026-10-15 16:35:07,882 INFO [EMailQueue.SchedulingThread] wt.system.out Administrator - com.sun.mail.smtp.SMTPAddressFailedException: 452 4.5.3 Too many recipients 经常是BG所在服务器内存使用swap的占比大于80%
Catalina
Community Manager
Hi ​@wangxuming
Thank you for your post!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Approximately how many recipients are included in the emails that trigger the error, and does it affect all notifications or only specific ones?
  • Have you checked whether the SMTP server has recipient count or rate limits that could be causing the 452 4.5.3 Too many recipients error?
  • Is the high swap memory usage occurring at the same time as the email failures, and are there any related messages in the Windchill BG/MS or mail server logs?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill  looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
How many recipients is the server trying to email in a single message?
How much memory does the server have?
How many method servers are you running?
