Sep 21, 2015 8:34 PM UTC
Soft -Type VS Attributes | What would be more useful ?
Windchillers,
If given an option; what would be more beneficial to configure ?  an attribute or a soft type ?
Let us say there are 4  list available for configuration on WTDocument:
1) ID : {1,3,5,7}
2) MATERIAL : {St, Al, Br, Cu }
3) TYPE_INFO : { Decoration, Lab, commercial, Household}
4) Country : {US, FR, AU, LA}
Would it be more beneficial to configure TYPE_INFO as soft type of WTDocument and then add attributes ID, MATERIAL & Country on each soft Type (Decoration, Lab, Commercial & Houehold) ?
OR
Would it be optimal to add all the 4 as attributes on WTDocuments ?
why ?
Sep 21, 2015 8:52 PM UTC
Hi Vaibhav,
This depends on many other factors. Do you want all objects to use same life cycle template ? Are you planning to have workflows for these objects based on TYPE_INFO. Do you want a separate OIR (numbering, folder, versioning scheme)? How do you prefer to search on these objects?
If you are planning to create separate types you may want to create a particular subtype first with all the required attributes and make it un-instantiable and then create other types under this which would be marked instantiable.
Bhushan
Hi Vaibhav,
Bhushan
Sep 21, 2015 9:01 PM UTC
Hi Bhushan,
Thanks for the pointers, Very useful. Yes, We might have workflows in future; and that would be an added advantage.
However from search perspective; would the search for an ATTRIBUTE be more resource intensive than that of a TYPE ?
Vaibhav
